SailNet Community - View Single Post - FW Pump, Rebuild?
post #10 of Old 08-05-2013
MHRitter
MHRitter's Avatar
Re: FW Pump, Rebuild?
I put Jabsco PAR 36800-1000 (3.3GPM 20-40 psi) together three times, but these last two times I could not get the center screw of the 9 screw bottom plate to get to the threads as if the center screw should be an 1/8 inch longer. I tried the 10-20 psi switch and most of the time it just would not turn on until I tapped it with a screw driver handle and the 20psi was never enough to get the sprayer to engage. Glad I saved both the large and small Pulsation Dampeners cause the new ones failed in short order .
[FONT='Tahoma','sans-serif'][/FONT]
Boating is Fun…Let the folks @[FONT='Calibri','sans-serif'] [/FONT][FONT='Arial','sans-serif']
[/FONT]
[FONT='Calibri','sans-serif'] [/FONT]show you how[FONT='Calibri','sans-serif'].[/FONT]
MHRitter is offline
