SailNet Community - View Single Post - Auto bilge won't work
post #2 of Old 08-11-2013
Waltthesalt
Re: Auto bilge won't work
Check connections, they're usually the problem. If you have a test meter, check that when you lift the float the voltage to ground goes from an open circuit to 12V. You could also use a DC light bulb.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
