SailNet Community - View Single Post - Removing pawls and main gear on barient winch
post #1 of Old 08-13-2013 Thread Starter
abrahamx
The directions may as well say " take all the parts off" When it comes to taking apart the pawls the directions on my tear down instruction sheet mearly says
"Remove four pawls (#20), four pawl springs (#18), and four plung ers (#19) from low range gear". I am not sure how exactally. Is it just a pressed shaft that needs to be hammered out. The main gear has a washer and a pin holding it in. Not sure if its a allen set screw or a pressed pin or what. I just dont want to start tearing stuff down without knowing the proper technique and how to put it back together. They appear to be pressed fittings that would be impossible to get back on if I were to get it apart. Unless I should be focusing on taking it off from the top of the winch. Barient 20 winch. any help appreciated.
abrahamx is offline
