SailNet Community - View Single Post - Mounting ST winches - where to point the arms?
post #2 of Old 08-14-2013
overbored
overbored's Avatar
Re: Mounting ST winches - where to point the arms?
read the manual, some winches are oriented for the direction of the sheet lead in direction for the max strength of the bolt pattern and then the arm is located so the sheet will lead into the cockpit. the arm is usually on the left side of the winch as you tail the line
"GOLD RUSH" PRINDLE 16
overbored is offline
