SailNet Community - View Single Post - Mounting ST winches - where to point the arms?
post #3 of Old 08-14-2013
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Mounting ST winches - where to point the arms?
The stripper arm should be at 5:00 o'clock to the person grinding. Also, the stripper arms generally are sleeved into the drum so by lifting the drum up off the splines it can be reoriented. Some winches like Lewmars have the stripper splined separately so that is all you have to adjust.
To mount the winches you want the idler gear to be facing the line as it enters the winch. Once bolted down, adjust the stripper arm as described and you're done.
SloopJonB is offline
