SailNet Community - View Single Post - Mounting ST winches - where to point the arms?
post #7 of Old 08-14-2013
overbored
overbored's Avatar
Re: Mounting ST winches - where to point the arms?
Consider the angle that you will pull on the sheet because before you can use the self tailing you need some tension on the sheet so you may be pulling the sheet in with it in the tailing cleat. even though you single hand you will have crew on some days and if you are to the rear of the winch the crew may need to pull more from forward of the winch. pulling across the arm does not work well. the instructions seems to be placing it a about 7 o'clock to the operator. mine are about 8 o'clock because the sheet tailer is forward of the winch but still works fine when tailing from the aft position
"GOLD RUSH" PRINDLE 16
overbored is online now
