SailNet Community - View Single Post - Flexifold and strut
post #2 of Old 08-15-2013
Fstbttms
I don't discuss my member
Fstbttms's Avatar
Re: Flexifold and strut
1.- Remove the zinc.
2.- Remove the cover plate.
3.- Remove the set-screws that secure each blade pivot pin.
4.- Drive out the pivot pins.
5.- Remove the blades.
6.- Remove prop nut set screw
7.- Back the prop nut off but do not remove.
8.- Put a deep socket on the nut, then attach prop puller.
9.- Remove prop.
Fstbttms is offline
The Following User Says Thank You to Fstbttms For This Useful Post:
davidpm (08-16-2013)
