SailNet Community - View Single Post - Removing Hot Water Heater
post #35 of Old 08-15-2013
DaveMancini
DaveMancini's Avatar
Re: Removing Hot Water Heater
Brian,
You are correct, it is "metric" or actually Japanese Industrial Standard JIS B 0203, which is identical to British Standard Pipe or DIN which the Japanese adopted some time back. That's why the drawings indicate "3/8" because the thread pitch is actually measured in inches. But it is not the same as US NPT pipe thread in either pitch or taper angle (I was wrong). Very confusing but the right plugs are readily available. The Yanmar numbers are correct, but may be more expensive than from other sources like McMaster Carr (I love those guys).
Good catch.
Dave
DaveMancini is offline
