SailNet Community - View Single Post - Why the Bristol 32 backs so poorly
post #3 of Old 08-17-2013 Thread Starter
davidpm
davidpm's Avatar
Re: Why the Bristol 32 backs so poorly
Originally Posted by chris_gee View Post
Also the centre of windage is forward giving a greater moment to the force of wind, than say the effect of prop walk at a lesser distance.
That is as good way to explain it.
If the pivot point is closer t the rear of the boat then the lever action of the prop walk and even rudder control is much smaller than the lever action of the wind on the bow which has a longer lever.
There is an amplification effect also when going in reverse.
It feels like what happens when you are trying to backup a trailer with a long extension. If you get off just a little it rapidly causes your heading to go off.
It would be very useful to be able to mentally calculate all this and be able to successfully back down a fairway even if it was at a bit of an angle.
davidpm is offline
