SailNet Community - View Single Post - Survey about Propane Burner/Oven Range
post #4 of Old 08-18-2013
MarkofSeaLife
MarkofSeaLife's Avatar
Dock
Re: Survey about Propane Burner/Oven Range
2 burner without the grill. (Beware the 3 burner may not be a larger stove so you need to fit 3 tiny pots instead of 2 normal size pots)
Its the direct replacement for the one I had before but it had a grill which was rusted out. The grill takes up valuable oven space.
Ensure you get the battery operated ignition. So much easier than matches or lighters on a boat.
Mine is 3 years old.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
