SailNet Community - View Single Post - Tartan(s), Sabre, Pearson(s), C&C(s), Catalina(s) - "Chesapeake Draft"
post #74 of Old 08-19-2013
chef2sail
chef2sail's Avatar
Re: Tartan(s), Sabre, Pearson(s), C&C(s), Catalina(s) - "Chesapeake Draft"
C&C cb is one of the line led back from the mast to the cabin top winch. We have it through a Garhauer triple rope clutch so its a simple as winching in...throw the clutch. No need to tie off. Can't drop it down though, must be lowered with tension or the boat shudders as its weighted.
Originally Posted by Robcooper0767 View Post
I guess the question boils down to (for CB's),....If you take care of them on an annual basis, making it part of your boat work over the winter haul out, inspection, "alignment", cable, line or winch, are they really any more problematic than any other piece of sailboat gear, or part of the boat (ie. oil change, winterizing water lines, engine, taking care of sails........you all know the endless list of things to do.
Are CB's, when taken care of, just another "part"?
@Chef2sail:
I'm open to CBs for the reasons you mention and my question above stands to all CB'ers.
I was on a friends Pearson 34 just the other day and he explained, and it was right there in front of my eyes, on the port side of the cockpit, on the vertical "wall" under the seating area (like where some engine controls are), there was a cleat and no kidding, regular line, probably 7/16's, that came up from a slot and was simply cleated off. I notice some of the other CB boats had winch-like setups in various locations, cockpit, table in cabin, etc.
R
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
