SailNet Community - View Single Post - A C&C 30 mk2 with 6'6" draft?
post #19 of Old 08-20-2013
Re: A C&C 30 mk2 with 6'6" draft?
Only 2 ways to do that, either install a tank level gauge or hold your breath and look into the inspection port. Theres a hole drilled in the plywood of the cockpit locker floor, thats your inpection port under it. It is a good sized tank at 33 gallons and gives you good autonomy away from doing regular pumpouts.
Drumroll30 is offline
