SailNet Community - View Single Post - Refrigeration -Using the water tank as a cooling water source
post #2 of Old 01-28-2007
sailingdog
Henry-
This is probably not a good idea. The amount of heat the limited water tankage can absorb before becoming too warm to work efficiently is relatively low. The reason they use raw water, is that the system has an entire ocean or lake's worth of water to dissapate the heat into.
sailingdog is offline
