SailNet Community - View Single Post - Busting rusted nutz
post #1 of Old 08-22-2013 Thread Starter
aa3jy
Busting rusted nutz
Off another site..might be of some use..
> Machinist's Workshop MagT recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this. The magazine reports they tested penetrates for break out torque on rusted nuts.
> They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
> *Penetrating oils ........... Average torque load to loosen*
> No Oil used ................... 516 pounds
> WD-40 ..................... ... 238 pounds
> PB Blaster .................... 214 pounds
> Liquid Wrench ...............127 pounds
> Kano Kroil .................... 106 pounds
> ATF*-Acetone mix............53 pounds
> The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
> Our local machinist group mixed up a batch and we all now use it with equally good results.
> Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
> Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix. *ATF=Automatic Transmission Fluid
aa3jy is offline
The Following User Says Thank You to aa3jy For This Useful Post:
TejasSailer (08-22-2013)
