SailNet Community - View Single Post - Refrigeration -Using the water tank as a cooling water source
post #4 of Old 01-28-2007
sailingdog
Vasco-
The water your system uses wouldn't be all that much warmer, since it isn't re-circulating the same water repeatedly, and adding heat to the same tank of water continuously... If you've lowered the cabin temperature by 10 degrees, you've put all that heat, plus some additional amount for th inefficiencies of the system into the water... If you only have 50 or so gallons to dump the heat into, rather than the billions of gallons avaiable in the ocean... the water will warm up rather quickly.
sailingdog is offline
