SailNet Community - View Single Post - what kind of headwind should a sailboat be able to motor through?
post #6 of Old 08-22-2013
aeventyr60
aeventyr60's Avatar
Re: what kind of headwind should a sailboat be able to motor through?
Some of that black smoke may be the built up carbon getting burned up and blown out at higher rpms and hotter running temperature as well as unused fuel. Not sure about the drop in RPM after.
You don't mention the sea state or if your running against the tide, all will impede your progress.
Hows the service history for your engine? Fresh fuel filters, oil filter, oil change, valves adjusted, Exhaust hose checked for blockage? Diesel fuel clean? Tank condition? All stuff that may affect your engine running condition, especially under load. How about your hull bottom and prop condition?
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
