From what I've seen of the Bulwagga... It has great holding but stowing it is a problem. It doesn't really sit on a bow roller, and due to its shape—it takes up a lot of locker space.
The Spade, Manson Supreme, Buegel, and Rocna all fit on a bow roller pretty well, and are fairly similar in size/design. I have a Rocna and am very happy with it...and know people who have the others I mentioned...
I've seen the XYZ...but never known anyone who has actually used the XYZ. It probably has some problems with stowing it as well, either in a locker or on a bow roller, due to the oversized plate it uses.
I would avoid a stainless steel
anchors, especially if you are cruising long-term, as they are really good for anchoring out for extended periods of time. I would also avoid the aluminum ones for similar reasons.
I don't like the design of the Bulwagga, since it seems to have a point of failure, since the whole
anchor connects via the central rod, which seems relative weak compared to the ones I mentioned above.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
