SailNet Community - View Single Post - Wakes and the depth gauge
post #4 of Old 08-26-2013
overbored
overbored's Avatar
Re: Wakes and the depth gauge
you need to look at the sender. many are mounted on the inside of the hull and epoxied, siliconed or glued in place and it may be loose. air between the mounting. hull and the water will make the reading off. it could also be a loose electrical connection
"GOLD RUSH" PRINDLE 16
overbored is offline
