SailNet Community - View Single Post - Lippincott 30 Water Under Settees
post #4 of Old 08-27-2013
4arch
4arch's Avatar
Re: Lippincott 30 Water Under Settees
Glad to hear your water tank leaks are resolved. For the mast wiring, if you unscrew and remove the piece of wood trim along the top of the aft bulkhead in the head compartment, it should reveal a terminal strip in the ceiling where the mast wiring is terminated. It would probably be worth checking those connections. My boat doesn't have the plug on the mast - it may be aftermarket. Mine also at one point apparently had the steaming light wired to work off the engine ignition but that connection was abandoned in favor of a switch.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
