SailNet Community - View Single Post - First Time Out: Checklist
post #19 of Old 08-27-2013
Seaduction
Re: First Time Out: Checklist
Originally Posted by jephotog View Post
I am in the same boat so to speak in terms of learning to Captain a boat. Except I am in 30 foot range with inboard engine, larger crews and more complicated electrical system.
I created this checklist to cover all the steps I could think of. You can filter out what you don't need for your sized boat and add what other steps you may want to cover. Congratulations on the new rating and your first sail.
Pre Planning
Day before
1. Charge AA batteries
2. Float Plan
3. Check Weather
Pack Bags
1. Appropriate Clothing
2. Flashlights
3. GPS
4. Navigation Kit
5. Cameras
Day of (at home):
1. Confirm weather
At Boat
1. Open all hatches to vent
2. Boat Walk Around (note
Dings on sheet)
3. Record Engine Hours
4. Check Rigging
Check Engine
1. Oil Level
2. Fuel Separator/Filters
3. Closed Loop level
4. Raw water strainer
5. Belt tension
6. Leaks
Check Tankage
1. Fuel Level (record)
2. Fresh Water Level
3. Holding Tank Level
Bilge Area
1. Dry
2. Test Pump
Batteries
1. Water level
2. Secure.
3. Test Main Switch and condition
of each battery charge
Through Hullls
1. Locate all
2. Inspect Open or close
3. Wood Bungs
Locate the Following
Boat Docs
1. Registration
2. Appropriate signage
Garbage
Oil
PFDs
1. One per crew (I,II or III)
2. IV for cockpit
Fire Extinguishers
1. Check charge and date
2. <26 1-B-I
3. 26-40 2-B-I or one B-II
4. >40 3-B-I or (1-B-II &
1-B-1)
USCG kit(other)
1. Signal Device
2. Horn
3. Bell if over 40
4. Flares 3-day 3-Night
5. Emergency Tiller
6. Anchor readiness
7. Charts
8. GPS/Navigation
9. Light
10. Boat Hook
11. Owners Manual
12. MSD
Crew Brief
1. Non-Swimmers?
2. Seasickness?
3. PFDs
4. Going forward
5. MOB
6. Radio
7. GPS
8. Engine
9. Fire Extinguishers
10. MSD
11. Water Conservation
12. Electricity Conservation
13. Lines in the water
14. Boat terminology
15. Proper Watch
a. Relative bearing
b. Kelp
c. Right of Way
16. See something say something
Departure Preperation
1. Winch Handle
2. Remove Sail Covers
3. Stopper Knots.
4. Remove Shore Power
5. Note Wind/Plan departure
6. Turn on Radios, GPS
Departure Brief
1. Assignments
2. Concerns
Engine Starting
1. Ventilate Cabin
2. Batteries to all
3. Blower
4. Glow Plug
5. Neutral
6. Throttle
7. Start
8. Ensure water in Exhaust
On my boat, I teach the "crew" how to work the head. Also I remove the plug from the knotmeter thru hull and insert the knotmeter impeller into it. I like the ABC fire extinguishers.
Seaduction is offline
