SailNet Community - View Single Post - Replacing engine mounts
post #17 of Old 08-27-2013
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Replacing engine mounts
WARNING!: REPLACE THE SET SCREWS ON YOUR PSS SHAFT SEAL ROTOR!! Do not re-use the set screws.
The set screws are meant to be used only once. If you re-use the same screws, the rotor will loosen, and your bilge pump will likely get a workout.
eherlihy is offline
