SailNet Community - View Single Post - Replacing engine mounts
post #19 of Old 08-27-2013 Thread Starter
YankeePSC34
Re: Replacing engine mounts
Originally Posted by eherlihy View Post
WARNING!: REPLACE THE SET SCREWS ON YOUR PSS SHAFT SEAL ROTOR!! Do not re-use the set screws.
The set screws are meant to be used only once. If you re-use the same screws, the rotor will loosen, and your bilge pump will likely get a workout.
Thanks for the warning. Well taken. I used new set screws. But I do not trust them anyway. Therefore I secure the rotor additionally with a Two-Piece Clamp-On Shaft Collar placed directly against the rotor.
McMaster-Carr#6436K38.
YankeePSC34 is offline
