SailNet Community - View Single Post - Gennaker downhaul on CS27
post #4 of Old 08-28-2013
PaulinVictoria
Remember you're a womble
PaulinVictoria's Avatar
Re: Gennaker downhaul on CS27
Gotcha, so I'd maybe just put a shackle through one of the holes in the furler fitting and get an amsteel strap that reaches just above the furler, and then have a block on the end of that. Then run a line from the tack, through the block and back to wherever you want to adjust it from. The ATN should take most of the strain, the strap/block etc should just allow you to then adjust the height. That's going to be the easiest and is likely to be plenty good enough, I've seen setups where they just had a twisted line between the uprights on the pulpit and that worked OK.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
The Following User Says Thank You to PaulinVictoria For This Useful Post:
cghubbell (08-28-2013)
