SailNet Community - View Single Post - Holding tank on P26
post #1 of Old 08-28-2013 Thread Starter
bblument
bblument's Avatar
Holding tank on P26
Howdy, all...
I've got a 1972 P26 with a flexible holding tank in the dinette locker with unknown capacity (6 gallons?) and no vent. I'd like to put in a rigid tank, but there's not much space in there; the access panel is 14" square, there's only 10" vertical clearance on the port side of that panel, and only 22" from the vertical wall most inboard to the far edge of the panel. I've found a couple tanks that would fit, but that doesn't allow for fittings. Dan Pfeiffer's site shows the tank underneath the v-berth, but he also moved his freshwater tank forward to allow for it. I'm not sure I want to go through all that.
Can of you current or former p26 owners chime in with how you had your holding tanks setup?
Thanks!
Barry
P.S. I do have Peggie Hall's book on order, but I'm hoping someone can chime in with specific location and other tips on the P26.
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza." - Dave Barry
bblument is offline
