SailNet Community - View Single Post - Smoke and CO2 detectors
post #6 of Old 08-29-2013
tommays
tommays's Avatar
Re: Smoke and CO2 detectors
They should really be on a 24 hour 12 volt circuit and they kind of fall under UL 2034
I fell it is a small investment and have a SAFE-T-ALERT unit
Marine Operating Specifications
UL Listed to UL 2034-2005 for Marine use, including March 8, 2007 revisions. Meets ABYC A-24 recommended standards.
Marine environment tested for salt water spray, cooking fumes, shock, humidity, temperature extremes, vibration and corrosion.
Power 12 vDC, operational range 8-16 volts.
Micro Current Technology: 60 milliamp (.06 amp.) current draw.
Widest Operational Temperature Range Available:-40F to +158F
(-40C to +70C).
Relative Humidity: 15% to 93%.
Confirmation Circuit: Yes - Circuit reconfirms CO levels before alarming.
Audible Alarm: Minimum 85dB @ 10 feet.
Case Dimensions:
Model 60-541 Surface Case - 5.5"W x 3"H x 1.3"D.
Model 60-542 Flush Case - 6.5"W x 3.5"H x 1.25"D.
Weight: 60-541 / 542 = 0.43 lb.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
