SailNet Community - View Single Post - How hot does your diesel run?
post #6 of Old 08-30-2013
Tim R.
Tim R.'s Avatar
Re: How hot does your diesel run?
Originally Posted by eherlihy View Post
My Universal M25 runs at 180F exactly.
A couple of weeks ago I was motorsailing through heavy chop in 'Vineyard Sound (trying to get to Cuttyhunk before dark), and did not realize that the angle of heel on starboard tack was great enough to partially lift the intake out of the water. After about an hour, I heard the "beep, beep, beep..." of the temperature alert (for the fist time ever), and quickly shut down the engine. I looked at the temp gauge, and it was no more than 185F. I checked the coolant level (which was high), oil level, raw water strainer, and the impeller, and found that all was OK. We changed tack, and sailed in to the outer harbor. I started the engine to get into the inner harbor, and all worked as it should.
I am glad to have both an audible alarm and a gauge.
Ed, you should verify your gauges accuracy before assuming it is correct.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
