SailNet Community - View Single Post - Moisture in decks
post #4 of Old 08-31-2013
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Moisture in decks
The areas that sound bad, are due to delamination. Delamination is probably due to the core rotting. In my experience, this is common with '80s vintage Pearsons. I believe that it is, at least partially, due to the way that Pearson Yachts sealed the stanchion bases to the deck; rubber gaskets.
If you love this particular Pearson 31, then make an offer figuring that it will need a core repair in the next 5-10 years. A professionally done core repair on the P-31 may cost in the neighborhood of $10K (YMMV).
If not this boat, look at other Pearson 31s. I believe that you will find that this is a common issue with mid to late '80s Pearson yachts - particularly on the port side.
eherlihy is offline
