SailNet Community - View Single Post - Cat 25
Thread: Cat 25
post #34 of Old 08-31-2013
TakeFive
TakeFive's Avatar
Re: Cat 25
Originally Posted by SlowButSteady View Post
Not exactly. Most modern sailboats, even those considered to be rather "heavy" cruisers, can exceed their hull speed under the right conditions. It is true that as a boat approached its hull speed more and more power is required to accelerate, but the relationship is not vertical. In other words, even at or beyond hull speed a larger power input (be it from you sails or from the motor) will result in an increased speed. The relationship just becomes steeper. I have had my Cal 2-27 going faster than hull speed on many occasions, and even cruisers can sometimes sail for days averaging speeds greater than hull speed.
OK, let's pick nits.
I don't disagree, but my answer was targeted at the OP's level of knowledge. He was asking if a blown out sail would go faster than a new sail, and the correct answer to that question is much more "no" than "yes."
I am aware that it is possible (and fairly easy) to motor beyond hull speed, though you'll burn a lot more fuel in doing so.
It is also possible to have the sails drive you beyond hull speed, but it is generally not comfortable, especially with blown out sails.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
