SailNet Community - View Single Post - 1989 Hunter 40 - A million questions.
post #23 of Old 09-02-2013
BarryL
BarryL's Avatar
Re: 1989 Hunter 40 - A million questions.
Hey,
The electronic thing on top of the tank is the fuel gauge. There should be a wire leading from the nut to your fuel gauge in the cockpit.
I also suspect the fuel return line is leaking. Should be easy enough to check while the engine is running. Lastly, where you motor sailing with the engine running at a heal angle? That might be why your seeing some leaks.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
The Following User Says Thank You to BarryL For This Useful Post:
smackdaddy (09-02-2013)
