SailNet Community - View Single Post - oil vs varnish vs epoxy
post #8 of Old 09-03-2013
JonEisberg
Re: oil vs varnish vs epoxy
Whatever you do, DO NOT USE "OIL", probably the worst thing you can do for exterior teak... Don't take my word for it, take Rebecca Wittmann's, varnish is the way to go for trim...
"Taking care of teak and other marine links."
I've used West epoxy to build up a level finish for the minimal bits of brightwork I have - tiller, handrails, and dorades... If you don't use a sanding sealer first, epoxy can really darken the hue of teak... Several coats of epoxy to build up to a smooth surface, then several coats of varnish with a UV inhibitor ( I've used Epifanes, with good results) The epoxy undercoat really helps prevent lifting of the varnish, seems to me, and I've yet to have any real "issues" using this method...
Of course, it also helps that all of my brightwork lives under covers about 99% of the time :-)
JonEisberg is offline
