post #4499 of Old 09-03-2013 Thread Starter
Re: oceanis 38
Originally Posted by JAndersB View Post
.. So I agree with Gelin, put better rig and deck hardware on this hull and you get something interesting. Not perhaps a Pogo or Opium but pretty close and loaded with crusising gear boats does not plane anyway. Naturally nothing to compete on a race course with but a nice, modern cruiser with similar ballast ratios as many others but a more sexy hull and a remarkable interior. And finally some decent hull windows in the right places...
Regards,
Anders
Humm, Oceanis are on the low end of ballast ratio. As I said, with a bigger rig, a boat that would be fast in all conditions except upwind with weather where the ballast ratio is fundamental to give power to the boat to go against waves, specially a fat one like the new 38.
Also a tricky boat to sail (with a bigger rig), with that huge form stability giving power to the boat...but on a gust, with the boat lying down, not much RM to bring it back.
That is not by mistake that the boat has that rig and sail area. A substantially bigger one would increase the possibility of knock down... and the boat with a not famous final stability (low B/D ratio) would not be properly brilliant recovering from one of those figures.
Check it out the B/D ratio in relation with draft from the Pogo or the Opium (same kind of hull) and you will see the difference.
Hanse that is also using that king of hulls has a much more substantial B/D ratio, at least on the 40fter.
