post #4520 of Old 09-07-2013
HMoll
Re: Interesting Sailboats
You misunderstood what I said. What is complicated is not the different basic weights of a boat but to know to what weight the builder is referring when they give the boat displacement (they don't say what type of weight they are talking about). As Anders pointed out regarding the RM 1060 that is quite common several weights being given by the same builder in different occasions. With the Bavaria 36 (2003 model) they started given 4.600kg then 5.600kg and in some cases 6000kg.
Given all these confusions and since weight is an important promotional advertiser and Brands are interested in given to the public the lowest possible weight the RCD stipulated a standardized type of weight that is called Minimum sailing condition (MSC) that should be measured the same way in all boats, including the same percentage of fuel and water, sails,oil and everything the boat needs to sail.
The problem is that even if the correct MSC as the MLD are on the certification papers the builder is not obliged to give the MsC has the weight of the boat on the promotional papers and many refer the lightship condition or even the designer estimated weight.
That's what I mean with complicated, not the different weights but to know of what weight they are talking about.
Can we start a "not complicated" short discussion of using B/D as an indicator of stability, to get THAT out of the way once and for all as well?
HMoll is offline
