SailNet Community - View Single Post - Power Cord/Adapter Issues
post #8 of Old 09-07-2013
manatee
manatee's Avatar
Re: Power Cord/Adapter Issues
Something else you can do is put a *slight* twist on the blades of the plug. Every time you remove or install the plug, the blades wipe themselves clean. You also get a more-aggressive contact with the socket -- the springlike socket contacts weaken & wear over time, giving poorer contact. About once a month or so, unplug & reconnect the plug to keep the contacts clean.
The 50-amp cable is a good idea too. I try not to run things at their rated capacity because it guarantees a short working life and leaves no safety margin. How long would your engine last if every time you ran it , you ran it full throttle?
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
