SailNet Community - View Single Post - Spirit 23 keel cable conduit blocked
post #1 of Old 09-07-2013 Thread Starter
riverspirit
I'm restoring a North American Yacht Spirit 23 and the conduit pipe for the swing keel cable is blocked near the exit, looks like there may be a piece of cable stuck in there. It was moored in saltwater and unused for a while so probably corroded. I cant push through the block with a snake and I cant pull it out from underneath up in the trunk. Does anyone have suggestions to unblock? I'm thinking about installing a new conduit or cutting the conduit at the access in the cabin floor near the blockage to unblock and reconnecting with a coupling. The conduit seems to be metal in a thick plastic coating.
If I were to choose between leaving the swing keel down or up, which would be best? There are a lot of shoal areas around but enough room to sail in the deeper water here in east central Florida. I will not be trailering.
riverspirit is offline
