SailNet Community - View Single Post - Raw water pump flow warning buzzer?
post #2 of Old 09-08-2013
Faster
Re: Raw water pump flow warning buzzer?
These are rare, certainly not a normal factory item either from the engine manufacturer or the boat builder..
As you say it would be simple enough, assuming an appropriately sized (line size and voltage) flow switch can be readily found. You should be able to tie it into the existing multi-point buzzer cct if you can puzzle that out and tie into it.
A pressure switch might be more easily found, more easily installed, and as effective.
EDIT.. belay that last.. it wouldn't detect a plugged passage, as pressure would still be there.. 'doh...
Faster is online now
