SailNet Community - View Single Post - M-20 Scow - Main Halyard
post #1 of Old 09-08-2013 Thread Starter
snow-dude
Rob
I recently acquired a 1981 Melges M-20 Scow in need of some TLC. In a previous post, we worked through my issues with something we’re calling the “mast ram”. My next hurdle is rerouting the main halyard.
It appears the previous owner performed an emergency repair. The halyard is designed to run inside the mast. On my mast (pic #1), the halyard exits the forward side of the mast through a nasty “DIY-style” hole. The halyard is sawing down the mast, creating a keyhole type opening.
I’ll reroute the halyard to run internally.
Question #1 - Where does the halyard exit the mast? I see two possible exits on the mast….1) an oval hole on the port side of the mast (see green line in pic #2) and 2) a recessed double-roller pass-though (pic #3). Currently a spinnaker line exits the oval hole.
Question #2 – How does the halyard “cleat”? In pic #2 there is a “shark-toothed” unit riveted beneath the port-side oval exit hole. The halyard ends in a loop. I could see the halyard loop hooking onto the “shark-teeth”.
Any help will be greatly appreciated.
Rob
Lake LBJ, TX
snow-dude is offline
