SailNet Community - View Single Post - Tachometer
Thread: Tachometer
post #2 of Old 01-31-2007
Valiente
Valiente's Avatar
Originally Posted by morganbill
When I turn the ignition key to on, the tachometer will cycle from 0 to max rpm and back about 10 times a minute whether the engine is running or not. Also the oil pressure gage is pegged high. Just wondering if this is as simple as a missing wire. The tach is run off the alternator and the engine is a Volvo-Penta diesel with a Volvo-Penta insturment panel.
Thanks for any insight.
Morgan Bill
That could be a number of things, (intermittant short comes to mind) but if it's any guidance, when I turn on the blower on my glass fuse-protected Atomic 4 (when its running), the oil pressure meter drops 30 psi, the temp gauge goes up 10 degrees and then both snap back when I push the blower switch in.
I've learned not to freak out, rather than to actually trace the issue and fix it.
Valiente is offline
