SailNet Community - View Single Post - CS 30 - basic info needed
post #1 of Old 09-10-2013 Thread Starter
gallilaw
Need to learn a few things about the CS 30:
Am I right that the hull is solid, NOT balsa cored anywhere?
Did the factory overbore and epoxy the drill-throughs where the deck hardware was mounted, or otherwise prevent water from getting into the balsa core at the deck gear locations?
Every model boat seems to have some "typical" trouble areas that will develop over the years. What typical problems should I be looking for when considering a purchase of a used CS 30? Which of those issues are in the have-to-fix category, and which should be considered deal-breakers?
Some folks say that the CS 30 was designed for the Great Lakes; but others say it is fine for coastal ocean cruising. Is there any reason why an coastal ocean sailor should stay away from the CS 30?
Finally: when the wind spikes, on my current boat I furl the jib, and sail on the mainsail alone -- reefing that only when the wind hits persistently more than 22 knots. The total "standard" sail plan on my boat is weighted: mainsail=57% and jib=43%. On the CS 30, the mainsail accounts for only 45% of the standard 462 SF sail plan. When the wind spikes, will the CS 30 handle well on mainsail alone; or what is the recommended response?
gallilaw is offline
