SailNet Community - View Single Post - coconuts
Thread: coconuts
post #24 of Old 09-10-2013
manatee
manatee's Avatar
Re: coconuts
http://www.amazon.com/gp/aw/d/B006T8ILTY/
Euell Gibbons has a good chapter on coconut: stages of growth, their products, nutritional composition & uses, and lots of unusual recipes. If you look in the exotic/international section of your grocery store, you may find canned coconut water and coconut milk. You want unsweetened/sin azucar. Down here in Florida, the milk is also found in the powdered/canned/condensed milk section; the water is in the soda section. We also can get frozen grated raw coconut.
If you can find coconut milk, try making haupia, a Hawai'ian coconut pudding.
4 cups milk
8 tblsp cornstarch
1/4 to 1/2 cup sugar
Mix dry ingredients, add enough milk to make a thin paste, bring remainder of milk to boil, add paste and do not stop stirring for about 5 minutes as it thickens; when it gets to the 'heavy plop' stage (very thick), pour into a bowl or mold & let cool - it will get quite thick - refrigerate for a couple of hours if you like.
You can make coconut butter/oil from the canned milk, too. Conchita brand has the highest ratio of oil to water. Refrigerate the can for a good while - I use a few days to a week - to separate the coconut oil from the water. The less you shake the can, the better your results. When you take the top off the can, you will find a layer of coconut butter floating on top of the coconut water. You can use it as is, or clarify it. Put it in a small pot over *low* heat (barely a simmer) until it stops bubbling (this is evaporating remaining water), strain through a couple of layers of cheesecloth into an airtight container. If you refrigerate it, it will congeal, but melts almost instantly on skin or in cooking.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
