SailNet Community - View Single Post - Replacement Sail Dimensions
post #5 of Old 09-11-2013
JimsCAL
JimsCAL's Avatar
Re: Replacement Sail Dimensions
Your correct about the main Faster - I was reading the wrong numbers. Main will work but be just slightly small.
With regard to the genny, does the Morgan have a furler or use hanks? What about the Chance? If a furler you need the correct size luff tape and the sun cover needs to be on the correct side depending on the rotation of the drum. If both use hanks, you should have no problem.
JimsCAL is offline
