SailNet Community - View Single Post - De-Masting
Thread: De-Masting
post #8 of Old 09-13-2013
davidpm
davidpm's Avatar
Re: De-Masting
While you have the mast down is a good time to see if the wires inside are running free or in a plastic pipe.
If they are free they will make a lot of noise when you are anchored out.
Easy to fix when the mast is down.
Also check the wires. It is a good time to replace them.
Practice the phrase. "While we are at it"
davidpm is offline
