SailNet Community - View Single Post - Run our 2012 Honda 9.9 hp outboard up out of the water?
post #2 of Old 09-14-2013
mitchbrown
Re: Run our 2012 Honda 9.9 hp outboard up out of the water?
its no problem running the engine as long as the Hose/Clamshells are delivering to the water pump. you can usually tell if the motor is pumping water as it will be spitting water out of the "pee hole" as well as the exhaust
mitchbrown is offline
