If you're really having a problem, you can always setup your
jib as a self-tending
jib.. This eliminates the ability to use a genoa, but then you wouldn't have to deal with the
jib during a tack at all.
The main thing that allows a single person to do all of this smoothly and easily is practice and familiarity with the boat. There is a rhythm or flow to doing a tack or gybe on every boat... and the more experience you have doing it, the better chance you have of realizing what that flow is, and how you can best keep it going smoothly.
Another problem or obstacle to single-handing on many boats is the setup of the
lines on the boat. If they're setup in the wrong places, then single-handing the boat becomes much, much harder.
It helps to have the mainsheet, the
jib sheets and the tiller within reach of each other, on a boat that is being single-handed... but this makes the boat a bit more complicated to sail with a crew... since you'll now tend to step on each other's toes... A good tiller extension helps a lot too...
POST.
