SailNet Community - View Single Post - CS 30 - basic info needed
post #2 of Old 09-15-2013
Oaksail
Oaksail's Avatar
Re: CS 30 - basic info needed
Hull is solid, nor balsa core. Deck is balsa cored but solid along the perimeter where the toe rail bolts thru and the genoa track portions are solid. Note sure at the chain plates.
Cockpit drain hoses should be replaced or inspected.
Solid core AC wiring should be replaced.
The holding tank should be fitted with an internal extension tube that will allow complete emptying of the tank.
I dont like sailing with only one sail up. The 30 has a quite a bit of sail (with the 150 genoa), It feels too unbalanced to me on just one sail. I plan on purchasing a good used jib this winter to be better ready next year for those 25+ knt days.
1989 CS30
Oaksail is offline
