SailNet Community - View Single Post - Question about singlehanding
Old 02-01-2007
Sailormon6 Sailormon6 is online now
Sailormon6 will become famous soon enough
My first suggestion is that you forget about adjusting the mainsheet while tacking. As a practical matter, the mainsail is self-tending when you tack. In a well-coordinated tack, the boom doesn't "smack." As the boat comes up to windward, the mainsail luffs, and then, as it falls off onto the opposite tack, the wind fills the mainsail gradually. When you're singlehanding a sailboat, you have to think like an expert in time and motion study. In other words, you have to eliminate every unnecessary motion, and accomplish everything as efficiently as possible, because you only have two hands, and, ideally, you need three or four.
Secondly, don't make any "fine trim" adjustments while you're tacking. You'll have plenty of time to make all those adjustments after the sails are filled and the boat is on it's new course. The essential actions are to (1) put 2-3 wraps on the lazy jibsheet and take up all the slack in the line, (usually 2 is best. After the tack is complete, you might want to put a 3rd or 4th wrap on the winch) (2) release the working jib sheet, (3) steer the boat through the tack, (with practice, you can tiller-steer the boat with a knee, or you can wheel-steer it, using the wheel brake to hold it momentarily) (4) watch the jib, and, as the jib crosses the eye of the wind, start hauling in the jibsheet, and bring it in as fast as you can, (the more you can pull in by hand, the less you have to crank in under load, using the winch handle.) (5) cleat the jibsheet, and (6) make fine trim adjustments.
