SailNet Community - View Single Post - Pros and cons of steel sailboats
post #1222 of Old 09-22-2013
outbound
outbound's Avatar
Above post makes sense but seems to speak more for building in aluminum. In large commercial vessels the weight of the hull built in steel has less of an impact on performance. As size decreases this becomes a greater concern and the strength may be viewed as overkill. In short one is incurring unnecessary weight with need for greater sail area and larger engines. With aluminum strength,puncture resistance,weight are more in keeping with size and actual use. Although galvanic concerns exist issues with coating do not. Hence, one reads of the extensive use of aluminum but not not steel by Alaskans for their skiffs and high latitudes sailors for their hulls. Unpainted aluminum still allows a very aesethically pleasing hull.
s/v Hippocampus
Outbound 46
outbound is offline
