SailNet Community - View Single Post - 4-stroke 6 hp Tohatsu Outboard Issues
post #2 of Old 09-23-2013
Gladrags1
Sailor
Gladrags1's Avatar
Re: 4-stroke 6 hp Tohatsu Outboard Issues
Bad gas is responsible for most operating problems. Try putting carberator cleaner in the tank and running it through. But first; does your motor have a window so you can see the oil level in the engine? I believe it should. Is the level at 1/2 way up that window? Do you have enough oil? If so, it's undoubtably bad fuel.
Keep a stabilizer in your fuel so you avoid this problem in the future.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
