SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #805 of Old 09-24-2013
obelisk
1982 Skye 51
obelisk's Avatar
Re: Low buck projects- Let's see 'em!
here is a backup voltage regulator that I just installed here in NZ. design came from Marine Electrics of Opua. It is a Bosch RE55 regulator for a car and a common relay for the ignition. well under NZD$100 and a great backup to a Balmar/AmplePower/etc. it is single stage but only set to bring battery voltage up to 14.2V so you may want to keep an eye on your electrolyte levels if motoring for an extended period but that voltage is low enough to avoid frying most lead-acid batteries (can't speak for gel, AGM or lithium). it is a fantastic backup that could save you a big headache should that costly "Smart" regulator fail at an inconvenient time.
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
obelisk is offline
