SailNet Community - View Single Post - Jeanneau Attalia
post #176 of Old 09-25-2013 Thread Starter
Waymar83
Not quite Senior Member
Waymar83's Avatar
Send a message via Yahoo to Waymar83
Re: Jeanneau Attalia
This is what I picked up this week from Practical Sailor: The Effects of a Tidal Stream on Navigation
The effect of a tidal stream is a significant factor when navigating on any point of sailing, but can be crucial when sailing to windward. If you are in a small boat sailing to windward against a strong tide, it can often prevent you from making any headway at all and it may be best to enter a port or anchor until the tide or wind changes direction. If this is not possible, you should try to keep to shallow water, away from the strongest stream. The presence of a strong tide will also affect the strength and direction of the apparent wind. When the boat is beating against the tide, the apparent wind speed will be reduced because the boat is being carried downwind. The converse also applies. When the tide is running across the wind on the lee bow, advantage can be gained because it increases the speed of the apparent wind and alters its direction so that the boat is effectively freed and can point higher. When the tide is on the windward bow, the effect is the reverse, so try and tack when the tide changes to keep it on the lee bow..... Wondering if this would have the same effect just offshore.
Mark
Now based in Barbados.... and wait for it.....the boat is too!
Waymar - Jeanneau, Attalia
Waymar83 is offline
