SailNet Community - View Single Post - windsensor for rotating mast, microPC needed for NMEA correction
Old 02-03-2007
sailingdog sailingdog is offline
Rotating masts are actually quite common on multihulls. Most Corsair trimarans have a rotating mast. The reason they're less common on monohulls, is that the engineering is a bit more complicated, and PHRF regs do not allow the use of rotating masts IIRC. Also, many monohulls are designed with keel-stepped masts, which eliminates the possibility of a rotating mast for the most part.
They already make gear that does this, but it is generally reserved for the racing market, on high-performance multihulls. For instance, you can see such a piece of gear at TackTick, which makes some nice wireless instruments for boats.
Epic- You wouldn't need to refer to the compass, but would need a sensor on the mast that tells you what the current angle of rotation of the mast is...so you could offset the wind sensor readings... this is how the gear from TackTick works IIRC.
